Fuel filter delete for your compounds..
ColdSteel
Drives a hybrid.
Aug 18, 2015
5
Irwindale, CA.
What have you guys done to clean up the install a bit?
I see a lot of folks made loops out of their fuel lines, but I don't want those lines hanging out near the turbo where they can get hot or kink/ flatten out..
I think I made a stainless solution..
Awenta
4,090
CT
Just delete them all. Run from lift pump to cp3.
gamudslinger88
Aug 26, 2011
322
I thought about running mine 1/2 line from the lift pump to a block but haven't gotten to a point of doing it yet. Not to highjack but I'm interested in seeing everyone's setups.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,327
364
Central OH
If you do a search, recently someone found a preformed hose that fit perfectly. It would take me a bit to track down the part #, but I believe it was either Ben or Josh that had posted it.
ILuvJDM
Jul 15, 2014
Austin, Texas
I think I found what you're referring to, but it's listed as radiator hose which I wouldn't be comfortable using with fuel. I tested a piece of heater hose back when I was doing the upper engine cleaner (since I couldn't find the right size fuel hose) and it started eating away at the rubber and turned my finger black when I swabbed the inside.
Dayco 71359:
http://m.summitracing.com/parts/dac...0tRsCtnN6ROnj_nLs4cEGU1Fg7EL4bHUNIaAnaw8P8HAQ
CarolinaHD
969
NC
Ran it about a year before I removed it. Never had any issues with it though just wanted the factory head back
ILuvJDM
Jul 15, 2014
Austin, Texas
Well that's good news, I guess they are fuel resistant. Maybe the heater hose I had from O'Reilly's was just cheap quality compared to the Dayco stuff...
