Mine sits right off to the side in the frame rail like mikes setrab should be mounted where all that hot air is and clearly still runs waaaay cooler
So you are running the Setrab in a location different from stock ?
Stock cooler use to sit right off to the left of my air dog in the factory spot (I removed it and trashed it). This is not mikes cooler, I had said its mounted like mike had had his cooler mounted. If by what you say, that the hot air from the trans, tcase, motor, ect was not cooling the fuel due to the factory spot, I should be seeing the same results as trashy
My fan sits to the back side of the cooler and pulls through the it. Only thing is the only thermostat I could find is 180*, so by the time the fan comes on it is already hot. This cooler flows WAY Better than the factory so I was hoping that would be enough to fix my problem but I guess not.
So are you cooling the pressure or return side with yours?
Well there is your problem, ditch the thermostat and put it on a switch. Turn it on after you start the engine and you will probably see much better results.
Thank you sir. I will do that
Are any of you guys cooling your lift pump return as well as the fuel from the engine? I am thinking about putting in a sump and returning all the fuel through the top of the tank.
what model cooler are you running?
Well.....that didn't work. Temps still got to 210* a couple times. Guess my next move is to move the cooler for better airflow. Even turned the truck back to stock to see if it would help. By that time the whole tank was probably so hot it was beyond cooling back off.(it's in the mid to high 90s here right now) It's getting really old having to clear the p0087 every time I pull a hill. I wish I could get the fuel temps under control so I can narrow the issue down more. Between my dads trailer and my boat I'm grossing around 24-25k, but my dad pulls the same setup all the time with his stock LMM with no issues.
Because I have been told by a couple of people that the hot fuel could be causing a couple of injectors to be returning too much fuel thus causing low fuel rail pressure.
its not a permanent fix for his issue but just like how the GM injector clean helps sometimes, same deal here. it does help fuel econ in the heat though. ive gained 1-2mpg on the last two towing trips ive done.
The only reason I can see is that you don't want the tank to boil, other wise your just losing fuel in vapors.Good to know.
I'm sure there's a reason everyone cools return fuel other than supply but why?
