Front oil leak?
Delta.Speed
123
21
I'm almost sure this has been posted somewhere before, but I used the search feature and couldn't find anything.
Anyone have any ideas what could be causing this oil leak around the front balancer area?
That line in the photo is pretty badly cracked, and the one above it on the bracket is also old. Im replacing both of them, but since the truck is getting torn down to the heads I figured I'd ask what else I can replace in this area that might be related to this leak.
Thoughts?
Sent from my SM-S908U1 using Tapatalk
Delta.Speed
123
21
Could be a few things. Crank seal, timing cover seal, powersteering seals and lines.
This is exactly what I needed. Im not trying to pin point the leak, more like get ideas of what I can replace to try and get it to go away. So thank you.
I'm gonna start with the timing cover and crank seal, and once those are done I'll clean it up and check for leaks.
Any other seals in that area that you can think of that may be bad?
