Following data log in the tune
darkness
1,584
611
vegas
I’ve run across a weird issue in my pulse width table. While following the data log the mm3 rows follow the log but the MPa column is stuck at 190. Both tables (with and without pilot) do it. I don’t know if I inadvertently hit something or what. A couple weeks ago it was working fine and half way thru it jumped to the 190 column and has stayed there on any log I pull up.
In the pressure table it seems just fine. Here’s some pics.
dndj
Boost!
Apr 13, 2019
302
Oregon
Your logged FRP units are in PSI but your data table is displaying mPA. I think both may have to be in the same base units?
dndj
Boost!
Apr 13, 2019
302
Oregon
I'm using V8.3.5 and I am able to right click on the table and change the column display units from MPa to PSI. Not sure if v7.5 supports that feature.
darkness
1,584
611
vegas
Well everything works in v8.3.5. Gonna have to play around and figure it out more. Haven’t figured out how to get a split screen between the log and the tune. Thanks for chiming in Dale!
dndj
Boost!
Apr 13, 2019
302
Oregon
The scan (log) and the tune should be in separate windows. You should be able to arrange them any way you want like any other applications under Windows, up to the limits of your screen size/resolution of course.
