Fire damaged DMAX-would u buy?
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
Found a DMAX/4l80e combo on Craigslist in my area. Good price. But fire damage on top of motor. Says its a 2007 with 10k on it. Isn't this a van motor? And my question is would it b worth buying? From the pics it looks like the turbo is in tact but I can't make out much more than that. Would the heads b usable? I'm thinking maybe I should pass on it. What do u guys think?
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
The vans are rated at less HP but that may just be tuning. I hope someone else will chime in about this.Whats to burn up top ? fuel lines, wire harness, AC compressor, alternator, belt accessories ,FICM, turbo, ECM. There is a lot, do you just need a good block?
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
Yes I have lb7 pistons and I want a block crank etc to build.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
if the upper valve covers dont look bad i would assume the heads are good as well as the shortblock. its basically a lbz so for 1500 its not bad at all
