EGT Readings
joegorby
Apr 12, 2012
98
42
Washington Pa
I'm looking for guys that have stock bottom end on LMM's running set ups like mine: Aftermarket single turbo, bigger injectors and dual cp3's
What are you seeing for EGT's at WOT?
On my hot tune I'm seeing real close to 1600 on an 1/8 mile. I want to try 1/4 mile but I'm afraid of popping a hole.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Boost seems normal. Egt's will always be high on a wot run, I think your problem can be solved with a little more fine tuning. Your egt's will still be up there regardless.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
They won't continue to rise at the rate you see in the 1/8th either. They will level off after the 1/8th.
You can also add a little timing to get the temps lower.
Have a good one,
Steve
Sent from my iPhone.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
They won't continue to rise at the rate you see in the 1/8th either. They will level off after the 1/8th. QUOTE]
I agree. My truck gets hot then actually cools down after the 1/8th. I see somewhere around 1600 peak and drop down to 1400 or so by the end of the quarter
joegorby
Apr 12, 2012
98
42
Washington Pa
I thought it lowers because your rail pressure drops. Is it the same with 2 cp3's?
joegorby
Apr 12, 2012
98
42
Washington Pa
Low rail pressure is high egts.......
I was going to talk to you later this week or next when we put my truck on the dyno.
I didn't want to bother you!! Guess i should of just texted you!!
It runs great!! I beat a supercharged mustang gt that runs consistant 12.0's at the flashlight drags on sunday
