E86b lml engine shuts off at 1000rpm after tune
Jakezed22
158
53
I’ve been playing around with some new OS on my Camaro. E86b. Found a truck OS I was able to swap segments to get cruise working on.
But now the engine dies at 1000 rpm. Traction control lights come on at that time also. Ever see anything like that?
—14 Camaro with 6l90 lml swap—
Jakezed22
158
53
Update:
I’ve changed all the CAN ID tables to
Match the tables of the other Van OS file I was previously using ( it worked good except the engine shuts down weird and the ecm won’t go to sleep causing battery drain)
My next step will be to swap individual segments to see which is causing the issue.
Jakezed22
158
53
Update: I’ve found the key to my issues is in the engine operation segment.
When I use one from a truck the engine will kill itself at 1000 rpm and flash traction control lights
When I use one from a van the ecm shuts off weird and won’t go to sleep.
I have tried a good ole 12669774 truck os in the past which worked well except no cruise. If I could find a van that came with this os i could pull the Speedo and system segments and be good……. I think lol
Reactions: DAVe3283
