dual rear wheel adapters
zlonsway
32
Im building a set of dual rear wheel adapters for a single rear truck. I was wondering if anyone would know the diameter of the wheel studs where they press into the axle. I want to drill a set of flanges so I can press the studs in. Any help is appreciated.
Kutchey2
Apr 15, 2011
122
I have some 1/2" rings that have the hole pattern laser cut. I can email you pictures if your interested. They are all ready to have the studs pressed in.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I would think the best way is to actually buy studs aren't you going to need them anyway? Unless some one has measured the actual shank or have one lying around going to be tough to get the answer.
Or you could measure your own. I just don't think you could get to the area to measure it on the vehicle.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I just measured a new gm wheel stud for a single wheel just above the spline that locks into the hub. Came out to roughly .605"
