Dexcool percentage??
serpa4
Feb 5, 2007
402
Been playing with cooling over the years and have always added more pure Dex to my system. Thinking I'm probably over 50% which would diminish the cooling effect. Will a standard coolant mix tester (floating ball) work with Dex like the green stuff or give a false reading? Tester currently says boil over at 15 psi is 263-265 degrees.
05lly2500hd
(903)293-6026
Feb 16, 2008
473
46
Texarkana, TX
It is a "hybrid" Organic Acid Coolant, combining the best of Dexcool, and the cavitation resistance of some of the older coolants, without the wear-related high silicate levels.
Plus it is not involved in any litigation. :)
I see!, i may just swap over. Any "local" places to get it at?
jmoore
POOR BOY
May 29, 2009
131
47
VA
Use this it will help keep it cooler.
BG Universal Super Cool®
BG Universal Super Cool® coolant additive is specially formulated for use in conventional, long life, hybrid and heavy duty coolants. It provides outstanding protection for all metals utilized in modern automotive cooling systems. It has excellent corrosion inhibitors, anti-foam capabilities, and is biodegradable in its unused form. Passes ASTM 2809 and ASTM 2570 in ASTM reference synthetic used coolant.
Part No. 546
Part No. 5468 12 oz. (355 mL)bottle
8 oz. (237 mL) bottle
