Dead ECM? Random Customer truck cannot read info
dirtymax36
2nd place is last
Apr 11, 2013
367
Putting a set of dsp5 tunes on a customers truck, 100% stock 02 LB7. I put the dsp5 in the ecm, and disconnected the batteries as I always do before i touch anything. I get everything done and try to read the stock file off and every time i get code $0101 saying the ECM has no data or connection. Granted, the truck still starts and runs.
Any ideas? Bricked ecm? Ive pulled fuzes to the radio and such, still no luck. The V2 is up to date also. never had this happen before and need the truck back on the road
Any help is appreciated.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
The ECM isn't bricked it it still starts and runs. If you connect the V2 to just the truck and not the laptop does it light up? Did the cigarette fuse blow?
dirtymax36
2nd place is last
Apr 11, 2013
367
Yes sir it will stand on its own if the laptop is not connected.
I have also check for updates and it all comes back good to go
paint94979
Beer Nazi
Sep 18, 2006
11,714
7
37
Try using v7.5 not V8... It's a communication issue. Seems most common with lb7's and lly s.
dirtymax36
2nd place is last
Apr 11, 2013
367
Tried pulling stock file off with v7.5 and get the same message $0101. It literally takes less than 10 seconds into the process and it gives that code. Truck still runs and does everything normal.
I've also checked the boxes for Alt keys, etc. Still nothing
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Wonder if it's had a tuner of some sort, then flashed back to stock with gm?
I've heard that will cause an lb7 ecm to be "locked" and won't read..
dirtymax36
2nd place is last
Apr 11, 2013
367
Just called the customer and he says he purchased the truck 3 weeks ago and took the PPE standard hand held programmer off and back to stock tuning. Shouldn't have any affect would it ? It almost acts like it's a locked ecm if you tried to flash a previously locked truck per-say.
dirtymax36
2nd place is last
Apr 11, 2013
367
It will not license also, I've tried to use v8 and 7.5....out of ideas besides a new ecm
baddaddition
Mar 10, 2013
287
Try to just read diagnostics with the stock truck, might be the wire in the obd plug. Had it happen many times. They are finicky at best. They use the cig fuse for communication. My 2cents.
Sent from my XT1254 using Tapatalk
1,623
Same thing happened years ago on my truck. Had Tony stumped, too. We never did figure out what the problem was. Just had to put another ECM in it and no more problems. I still have that old ECM somewhere.
