Dashlogic?
Chad W
Apr 20, 2013
25
Ft worth, TX
Anyone have anything to report on these dashlogic OBD inputs for the dmax? I don't see it really being superior to efiLive or doing anything that efilive can't. Price isn't bad at $250 I guess. Only data logs as far as I can tell.
1fstlbz
Oct 16, 2014
I've seen a few, there pretty cool and seem to work alright. They basically work like any other gauge that plugs into your ob2 port. Not as fancy smancy as a cts monitor but does similar things.
PACougar
2,105
42
El Dorado Hills, Ca
It's pretty simple, if you don't want to add any physical gauges this allows you to view everything through the DIC on your dash. I wouldn't compare this to EFILive in any way, the two don't have comparable features. EFILive will let you datalog and tune, Dashlogic let's you view sensor data in your instrument cluster.
Bill T
Jul 18, 2018
Fort Worth, TX
I recently installed a Dashlogic module with the PLX SM-EGT module. So far I like it. Having the EGT's displayed in the DIC is really nice, as I did not want to add a gauge pod to the pillar or dash. Install was really simple for the Dashlogic. It's just plug-n-play. And the install on the EGT sensor and module was pretty simple. When I tried to add the EGT in the Dashlogic software it got a little tricky. But the guys at Palmer Performance Engineering were helpful with getting me the correct formula.
