Looking for a little bit of help in diagnosing a low rail pressure issue, as well as some info on these stock lift pumps.
P228C Fuel Pressure Regulator 1 Control Performance - Low Pressure
P228B Fuel Pressure Regulator 2 Control - Forced Engine Shutdown
Running the big tune and towing. Leaning on it in the hills, rail pressure drops down into the low 20s and desired is 26-28k. Lift pump pressure holds steady @ 55-65 psi. Throws the 228C. If I keep my foot in it for longer than 10 seconds, it will throw the 228B code and go into limp mode. Shifting down into fourth, the pump will hold 28k desired and actual. It will still drop slightly if I really lean on it.
I’ve had a few different shops try to sell me a lift pump saying I need one to run that big of a tune. IMO, A bigger lift pump pushing more psi won’t do anything for me since the stock one is still pumping fine, right? IIRC, the Fass pushes around 80psi and needs pressure codes turned off because of it.
I’ve ran like this for 65k miles already, and only recently started to throw these codes. Is the stock HP4 just getting weak? Will measuring the fuel return rate while the engine is running tell me anything, or not?
If the ECM pulls power because of a hurt transmission, could it show up in this way, or not?
I replaced the driver side fuel rail including that regulator, since I know that they can have an issue with sticking. No change. Looking for any help in diagnosing before I blindly throw a bigger injection pump at it.
