An update on this - The truck hasn't leaked a drop of coolant since it's been in my driveway. On Friday, I finally pressurized the cooling system. I pumped it up to 10psi and let it sit for over an hour. Not a drop of coolant and after that hour plus, the gauge showed about a 1psi drop of pressure, which could potentially be accounted for with the fact that when I started the test, the sun was shining full on the engine, and by the time I took it down, the sun had been off it for at least half an hour. I would have thought that since it was leaking while sitting, 10psi should have made for a nice stream of coolant, but no dice. Any thoughts?
