Converter? Clutches? Reset? WTF
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
Fuel filter head was leaking and causing low fuel pressure and Trans line going to to cooler had a slow leak. I've been watching fluid levels and adding when needed which was not very often. I'm thinking maybe the Trans adapted to low fuel pressure and is still compensating. I rebuilt the fuelfilter head and checked Trans fluid level, level was good but had some dark (clutch material) on the rag. Shifts great just has hesitation from 2500-3000 rpm. No codes and no limp mode. Runs great in two haul. I'm running dsp5 efi tuned by rob that is "tranny safe" any ideas?
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
You're saying that you had clutch material on the rag? If so I would assume you have a lot of debris fouling things up. Is the magnet still on your spin on? When is the last time you changed the spin on?
I would drop th pan and change the sump filter along with the spin on reset all taps and hope for the best.
