Ahh man, hate too see that James. That bottom end has been a trooper over the years for something like that to happen to it. What’s your plans now?
Dang, that blows.
Do you think that cylinder was hydrolocking too? I would've guessed it would bend a connecting rod before that. Sorry man.
Now that sucks. Sorry to see it, James. Standard 125ft/lbs on the studs?
Let me know when I can come over and help James...![]()
Basically have the whole top end. I just will be changing pistons for sure. No sense putting delipped lb7 pistons with 220k on them back in when fingers won’t ever be an issue. Then there is the fact I’ll be at the crank, keep the stock one with 220k or put a narrow journal crank in and never worry about that?
This is what kills me.
Yup stock crank and you are probably right. I just over build on my personal stuff (within reason) and there is a fix available so it’s a fight in my head.
At this point, I’m looking at LML block options. See what I want to do for cranks when I get near that point.
I just don’t trust mahle race cast. I truly feel they are marginally better than my delipped pistons. The smoke/mpg is a concern on fingers but I’m curious if getting a real tight piston to head clearance and keeping piston to wall clearance tight will keep it minimal. I’ve been running .025-.029 clearance on the engine now and it liked it. I’ll probably have Jon leave the pistons full length and I’ll turn them on my lathe after the block is decked to get me down around .022-.026 on grade A
Have you looked at pricing on LML bottom ends either new or used, probably the most hassle free way to do it
Well is an LML short block better to start with or a stock style block
