Carnage Boys
last_one
Mar 22, 2008
57
I had a hunch I needed to pull my trans the other day.:eek:
well I need to go to work, just thought I'd give you something to look at this mourning.
last_one
Mar 22, 2008
57
Well I think maby it was just cracked, cause it was just rattling at first then it got worse alot worse:mad: I just got my 4wd working again and tie rod sleeves. I think that might explain some of this? Any way I was just pulling into the dump when I got a p0766 code then when I tried to leave it would not go fowards but it would go in reverse. didnt throw any more codes. I have the tranny out but havn't opened it up yet. maybe tomorrow evening, I will dig in:D I already had burnt c3s and have been running it pretty hard.
last_one
Mar 22, 2008
57
Hey Reno How you been doing. I was thinking today at work about giving u call.Ive been really busy this whole summer things should start slowing down here soon. I opened up my trans last night c3's are still burned but not much worse than before. My c2's on the other hand are toast and some of the clutch material was coming of in chunks:werd: and I got a busted off bolt in my converter:damnit: Im goin to try and get it out tonight. Mike thinks I probably wont be able to get it out, but i have stubborn detemanation on my side:banghead: Anyway wish me luck. Reno maby I'll give u call tomorrow if I have time.
last_one
Mar 22, 2008
57
That center round piece that the converter slides into, that u can see is broke in the last pic will i be able to replace once the flex plate is off?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i dont know if its part of the crank or if it bolts onto the crank i hope its not part of the crank :(
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
You can give me a call anytime. If I dont answer leave a message because Im either at school or work.
