Is there anywhere under the truck or even in the truck to tap the cargo light wire somewhat uninvasively for the 2001 model year (pre-2003 redesign)?
I want to add a pair of LED lights to the rear bumper of the truck pointing out at a 45 degree angle, and have them come on with the cargo lamp or reverse lights (I can stick a diode on the double tap for that). I'll be adding a set to the trailer as well, and re-wire the reverse pin of the trailer connector to reflect the diode modification.
That way they'll come on when backing up or when the cargo lamp is on (so that we can see behind the trailer while pulling forward to re-position). But the dome light tap would be nice. Don't our trucks have a tap for it under the bed for a camper shell, or is that only for the 3rd brake light?
Also, i am aware the cargo lamp is a toggle ground setup. For what I am doing, that is fine, I can relay it to do what I want.
