Can't hold the truck back
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Chris you need to buy a single cab, that's what I did and it fixed the problem :D
I thought you did the Flintstone thingy anyway? :D
When I first started reading this thread I wondered if the original OP just had supermodel runway legs? Then I seen others had the same issue so diss-regard! I was going to recommend squats to build up leg muscles! :D
magnethead494
go fast crew chief
Dec 29, 2013
222
Fort Worth, Republic of Texas
on my dakota, I was pushing through the brakes as well. I know you guys won't like this, ut on the last brake change, I went to the softest, dustiest, "crappiest" brake pads that O'R sells. Problem solved and my truck tries to fling me out the window on a panic stop if the don't lock up. Yes my front wheels are 9 kinds of black, but they hold the truck and it stops great.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
45
Natrona Heights PA
is it a pulse or is the brake pedal just kicking back at you? the brake kicking back once indicates more of a hydroboost issue.
ive never known a bad wheel speed sensor is cause weak holding back of the truck like ben stated. most ive seen is them causing a pull when braking at 15-20mph and slower (not below the 5mph threash hold though). just cause you have a new hydroboost and pump doesnt mean they are working 100%. my pump is starting to whine on my truck and i noticed some decreased braking while pulling my trailer back home yesterday.
James, It doesn't kick back at you. It feels like there's zero brakes for a second. The pedal goes limp & the truck will roll forward another 5 feet before stopping completely. This happens every time I come to a stop.
Did you ever figure this out Chris?
Nope. Still does it. I did notice that when staging its best to stand on the throttle and then back off as it comes up on boost. But it still starts to creep forward at 10 psi. The charger lights really quick, so I don't think its a stall issue. Maybe tuning could be the culprit????:confused::confused::confused:
8,237
That sounds more like a pump issue
Bonestock
1,358
Worland Wy
Wouldnt the correct converter stall for the application being used work out better for getting on the chargers vs. trying to push thru the brakes with too low of stall?
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
I seen a post or two mentioning the 1058 converter possibly...Thats a 2300 stall and would suspect much different maybe if you had a 1057? I have a 1058 myself and i can get to 20psi easy I have a 3794 stage 2 charger
DMAXchris
Apr 28, 2009
2,273
45
Natrona Heights PA
My cousin has the same TC with a tct 472 & 100s. Itll go to 25 psi in about 4 sec. Brake pedal stays hard as a rock. There is some other issue. I shouldnt be able to push the pedal to the floor while staging. Maybe this "new" pump is junk?.
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
I recall another guy having an issue here with a built trans everyone thought he couldnt drive but the truck just wouldnt hold back, trans eventually took a s*** on him but i dont know what the outcome was.
WVRigrat05
3,149
41
French Creek, West Virginia
Sounds like my LLY, took 3 pumps a steering box and a cooler to get it right. My LMM did that for 3 days after a flush cooler and new pump. After 3 days and a hard hard run it was fine, air somewhere I guess.
DMAXchris
Apr 28, 2009
2,273
45
Natrona Heights PA
UPDATE:
ABS light came on two days ago and the brakes started working like they should. No more weird pedal when stopping and its almost impossible to push it to the floor. I can hold it back up to 20psi. It actually blows the tires off now in 4hi!
My thoughts are its a wheel sensor/hub going bad. How do I figure out what corner it is?
8,237
UPDATE:
EFI will read the code and tell ya.
SwitchBack
Sep 8, 2012
307
Vermont
I had an lly that had a very similar issue. It was almost like the abs was coming on right before you came to a stop. Ended up being the wheel speed sensor and I swapped it out and didn't have an issue since. The only issue is I believe they only sell them as a whole wheel hub assembly.
I pulled them all out and scuffed and coated them at that time so I wouldn't have further issues.
1slomax
Dec 6, 2011
260
Harrisonburg VA
let me know what you find out, my truck doesnt hold it self back in staging sometimes has a 1055 converter i think its 2600stall when it does this it pushes threw the brakes at around 2k rpm
