Here is the specs on the cam (DPR) i have been running in my 3.0 puller. 470* intake 459*exh 112*centerline 232 dur intake 230 dur on the exh cam is retarted 3.2*
I can't get the egt down and have gone threw three sets of heads. the first two had oversize intake valves and melted the exh into the water port. The set of heads on it now have stock size valves but keeps burning the seats up i get about four hooks before i loose compression The egs are 1900 @ the end of the hook. Do you guys think the cam is the culprit of all the heat??
