PureHybrid you are correct, I have measured a stock cam and have a program that will tell me lift at TDC and I wanted to check if calculated and measured are the same. Also I notice that when some of the members purchase after market cams they have to cut deeper pockets. This makes no sense to me because especially if they have increased boost they would want less overlap. Overlap is a tool NA engines use to help the gas exchange at lower speeds. forced induction does this for you, perhaps there is some tuning advantage I do not understand. Thanks
