I think we're going to need a little more info on how you're measuring it. I would guess you're looking for the max height between the top of the piston and the bottom of the C3/C4 top plate correct?
Typically aftermarket C3 top plates range from 0.380" to 0.425" depending on manufacturer. Goerend mainly uses a 0.400", I haven't had any issues with setting clearances.
As for C4, you don't cut it to run a 6 friction setup with an LML piston/return cage assembly. Even a 7 friction can be done without cutting it.
