Yeah, I want to use better head studs. I know there are a lot of people that haven't had any issues with regular ARP studs, but if something bad is going to happen it will happen to me. I am also going to have the block decked. It's probally not necessary, but I can't have my truck down later on for something that I should have done from the get go.
:rofl: I had her out there helping me last night, but she is to tiny to get enough power to hold the flywheel still.
I like tearing stuff apart by myself. It's the accomplishment feeling.
No this damn bolt is tight. I have a friend that I am going to introduce to the bolt tonight. It's called a torch.![]()
No torchI just went through this with mine, Broke a 1/2 breaker bar and a 3/4 to 1/2 reducer from the impact
If you can get the socket in a 3/4 drive and a stout 3/4 impact, it will come off. You could also try the breaker bar method again but smack the head of the bolt a few good times...
Just my .02 on the subject......when I replaced my water pump I bought a 3/4" breaker bar at Habor Freight. Then slide a 60" piece of rigid conduit over the breaker bar......bolt came loose no problem.
You don't loctite that bolt it's a stretch fit bolt, you've got a big problem.
Is the bolt a reverse thread?
There is a small leak right below the balancer. Would this be from the front main seal?
That looks to be where the PCV vents on the LB7s. Is that what the motor originally was?
Its the seal behind the balancer. The one that is pressed fitted into the timing cover.
I got the seal out. Where is the best place to get the seal driver? Does the timing cover need to be in place first? Will the seal driver work for the seal on the flywheel housing?
