I don't see a FAQ section of any sort, so I will ask. What are the best source/brands of injectors? How can we tell if we have stock flow injectors or overs/what % overseas if so?
What? You can get them flow tested for well under a grand. I know they do baseline flow tests for 50$ an injector. Why don't you call them man.So $400 per injector with core charge ($3200) and $250 without ($2,000) from exergy, assuming that our truck is untuned and has stock injectors.
We still need somebody with EFI Live to plug in and see if it is in fact tuned, as if so I'm pretty inclined to guess that we're going to be up injector creek.
care to elaborate?
muff. To my knowledge the only way I know to tell size is to flow the injectors.
Bought it at a dealership. No info on PO. It has the big-head wastegate, boost & EGT gauges, a 52 gallon underbed tank, adjustable shocks on all 4 corners, and 2 add-aleafs in back, that we have found so far. I wouldn't be surprised if it was tuned, as it seems to be set up for power & monitoring that power.What? You can get them flow tested for well under a grand. I know they do baseline flow tests for 50$ an injector. Why don't you call them man.
Also, why do you think it has bigger injectors? Can you not talk to the prevouis owner?
