Best 2.5" turbo?
2005LLY
Sep 18, 2011
379
If I have to stay stock appearing what is better Fleece 63mm billet cheetah, or Danville stage 2? If I don't need to stay stock appearing what's my other options?
Thanks Dylan
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
I've had a Danville charger for over two years. It just rips. The customer service is top notch. And he's only made them better since I put mine on
moss
<--good vibrations
Dec 15, 2008
296
45
sandwich, il
theres a duramax down around Kentucky running an ED turbo that seems pretty tuff when it makes a pass
MarkBroviak
DMax Junkie
2,231
740
Danville Indiana
There is about a 150-200hp difference between 2.5 stock appearing and ITPA/bob 2.5 class so you need to be more specific with what you are looking for. I have stock appearing guys in the 750hp range, best 2.5 vgt power was 720hp, my custom billet S463 in the 850+hp range.:thumb:
2005LLY
Sep 18, 2011
379
What's this 2.5" stock appearing Danville charger I've seen that is like a 68mm with a 2.5" cover I'd be very interested in that!
moss
<--good vibrations
Dec 15, 2008
296
45
sandwich, il
the points leader in the b.o.b. runs one of yours. the guy hangs right in there with the heavy hitters even though he doesn't have duals or even dual fuelers!:thumb:
Dozerdog74
Lost Cause
Sep 13, 2012
101
Montgomery, IN
Hey Mark, what would your 463 do for my pile?? think it would finally finish me off????
Burris
carpenca
Dec 17, 2010
168
Hell yes you could Ben! You could also use the big 2.5 turbo since you are still rocking the true 2.5 S4! would be 100hp increase for you!:thumb:
Chase Fleece sure is looking forward to getting to those rule meetings this winter and getting the "big 2.5" stuff out of it, and getting the clarification established so that it remains a True 2.5" class and as an intermediate class between Work Stock (Stock Appearing) and 2.6". With the way its headed now, we are only a water to air and weight box shy of 2.6".
The lack of rule enforcement, and teching each pull has allowed the class to get out of hand in both Indiana and Kentucky, which is a shame.
Indiana Truck Pullers Association 2.5" Diesel Turbo Rule:
26. S-4 Turbo is the largest turbo allowed. Turbo must be a true 2.5 charger. No clipped wheels or step
down covers. ¼ inch MWE groove maximum. Inducer bore must be non- removable. All air must go
through 2.5 inducer bore or MWE groove. The wheel must protrude into the 2.5 bore 1/8”. Turbo will be
checked with a 2.550” plug. The driver will be responsible for making compressor wheel and bore
accessible for tech officials to measure bore and inspect compressor wheel.
http://www.indianatruckpullers.net/Documents/2.5 Diesel 4x4 Rules2013.pdf
Battle of the Blugrass 2.5" Work Stock Turbo Rules:
Turbocharger:
S-4, GT 42, HX 50, LLY, and turbo of this type is the largest turbo allowed. T-4
mounting flange is the largest allowed. Turbos must be a true 2.5 charger. No clipped
wheels or step down covers. Billet compressor wheels are allowed. A single .200 inch
MWE groove maximum allowed. Inducer bore must be non-removable. All air must go
through the 2.5 inducer bore and the MWE groove. The wheel must protrude into the 2.5
bore 1/8 inch. Turbo will be checked with a 2.550 plug or internal calipers.
The 6.4 Power Stroke engine may utilize the factory twin turbo configuration. The driver
will be responsible for making turbo accessible for tech personnel to measure and inspect.
If you have any questions regarding turbo rule contact Battle of the Bluegrass Technical
Department.
http://www.bluegrasspulling.com/docs/bluegrass 2.5 truck rules 2013.pdf
Caleb
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Please excuse my ignorance, does the Danville stg2 vgt68 fall under the 2.5 class turbo?
