Ben, need some connector/pin/wiring advice
1,629
I figure you're the guy to ask about making a CD changer wire harness.
Where do you find female connector 12047531 and pins 12146447 or 12146448 depending on wire dia (10 way F Micro-pak 100 series (BLK))??
That begs the question, what size wire should I use? 22ga?
Then, I have to tie into the radio wiring. Its not a "normal" radio connector. Its part number is 15356942, and I cant find the "pins" for it anywhere. The description of the connector is "32 way M DNL RW (BLK)".
I figure I can buy the circuit wire anywhere, but isnt drain wire special? If so, where does a person find that?
Any info/advice would be appreciated. Thanks.
onebaddmaxxx
1,212
Cecil County Md
Tom-
Do you have access to gmglobalconnect? If not let me know what the radio is in. If it's your 03, I can go on there in the am, and in the master electrical diagram find the radio plug and it will give me the pin part # for the plug
1,629
That plug, when paired with its twin, is actually one of the GM radio plugs from the '80s! :rofl: Its a "Factory Radio OEM Reverse Male Wire Wiring Harness 11"
I found everything I need thru the aftermarket, but I swear I have one somewhere in my car electrical box from an old Cutlass or 98. :roflmao:
onebaddmaxxx
1,212
Cecil County Md
If you want tomorrow, I can look it up for you and answer everything in the original post if you still need to know? SI tells you which wire to use as well
