I figure you're the guy to ask about making a CD changer wire harness.
Where do you find female connector 12047531 and pins 12146447 or 12146448 depending on wire dia (10 way F Micro-pak 100 series (BLK))??
That begs the question, what size wire should I use? 22ga?
Then, I have to tie into the radio wiring. Its not a "normal" radio connector. Its part number is 15356942, and I cant find the "pins" for it anywhere. The description of the connector is "32 way M DNL RW (BLK)".
I figure I can buy the circuit wire anywhere, but isnt drain wire special? If so, where does a person find that?
Any info/advice would be appreciated. Thanks.
