So I had my Speedo jump from 60 to 30 the other day which I just figured it was a stepper motor and would be an easy fix in the cluster, until the transmission started getting stuck in gear and not shifting right. I’ve done some research and to my understanding there are 3 speed sensors on the transmission and one on the transfer case which is the VSS. I ended up replacing the sensor on the transfer case today but didn’t seem to fix the issue. I guess my question is how do I know which one is bad out of the 3 on the transmission? Can I do an OHMs test on them even though the problem is not happening consistently?
