B/W efr turbos
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
haven't been released yet
I have held a few in my hands , and can get most , but the only one really usable for use diesel guys in the 68mm inducer and it is not released yet ,
"technically" I have 3 on order but they have been since last year so .......... they do have a 62mm inducer i will be trying out shortly , on paper it flows the same as a cast 66mm but will spool much faster , i will post up some info when i install the one i ordered, it will likely be a few months though .
Iceman56
Jan 19, 2009
867
Madison, SD
"technically" I have 3 on order but they have been since last year so .......... they do have a 62mm inducer i will be trying out shortly , on paper it flows close to a 66mm but will spool much faster , i will post up some info when i install the one i ordered, it will likely be a few months though .
Are the others too small Trent? I also thought I read in a magazine that the max EGT's for these turbos is only like 1760 degrees... That wouldn't work for the guys really pushing the turbo would it?
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
I think we may have read the same magazine Iceman56. But if I remember correctly i think it said 1760 without being oil or water cooled. Not sure if that makes any sense or if that is correct. :confused:
TrentNell
Jul 7, 2008
7,543
46
slc tuah
It doesn't make it un usable just would have to.make sure they are sized properly for the hp level, if it was sized properly egt's should never be that high.
