When assembling the crank bearings do you put assembly lube on both sides of the crank bearings? Including the thrust bearings? Even on the bearing caps and in the cradle where the bearings sit? Im new sorry if my terms aren't correct.
I used assembly lube on the thrust to keep them in place. On the mains I just coated the crank side.
Maybe you shouldn't be building an engine???
It's not rocket science. With Google and YouTube people can do just about anything.
Duh. The Internet is never wrongOf course, Because if its on the Internet it has to be right!![]()
Or pressurize it externally.everyone has to start and learn somehow, there is only one way to do it. Its also a good idea to crank it a bit with the ficm un plugged to prime the oil system, remember its not a small block it wont prime in 2.8 secconds.
