Anyone swapped in GM stock replacement fuel lines?
turbo_bu
157
5
Central IL
So I started to replace my fuel lines with the Dorman kit. Looked good, but didn't fit very well. Worst part was that the return line was about 1.5" too short up at the engine. So, I am sending those back, and was looking at just using the stock GM kit. Main issue I see is that the GM kit is all 1 piece. There are not any junctions like what the Dorman kit had.
Has anyone been successful installing the 1 piece GM fuel lines? It almost looks like I will have to at least remove the ABS unit and/or the torsion bar cross member. Not really liking this option. Are there other "kits" that guys have had better luck with?
Bdsankey
2,685
190
Neenah, Wisconsin
I've only ever used the Dorman or similar kits and have had a similar issue to what you're having but countered it by just adjusting the routing/moving them and finally got them to fit.
CarolinaHD
966
3
NC
I used the Fineline kit from rock auto and it fit alot better than the dorman. Seem to remember 2 of the hoses being a little long but it all worked.
