DTC B1372
Circuit Description
When the ignition switch is in the UNLOCK position, certain class 2 messages do not transmit. The instrument cluster suspends the operation of the indicators and the gauges that are dependent on these messages until the ignition switch is no longer in the UNLOCK position.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B1372 Device Ignition 1 Circuit Range Performance
Conditions for Running the DTC
The ignition is ON.
Conditions for Setting the DTC
There is a difference of at least 75 percent between the ignition 1 voltage circuit and the instrument panel cluster (IPC) battery positive voltage circuit for 3 seconds.
Action Taken When the DTC Sets
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>The odometer and the PRNDL displays do not illuminate.</TD></TR></TBODY></TABLE>
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>The fuel gauge and the engine coolant temperature gauge default to 0.</TD></TR></TBODY></TABLE>
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>The scan tool does not communicate with the instrument cluster.</TD></TR></TBODY></TABLE>
Conditions for Clearing the DTC
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>The DTC becomes history when the conditions for setting the DTC are no longer present.</TD></TR></TBODY></TABLE>
