Any sites for GM SMALL parts lookup?
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
899
29
Western MA
www.matpa.org
Are there any places online to look up ALL OEM parts for a 2006 GMC 2500HD 4WD CCSB SLE?
I have been looking for parts numbers for the following:
Front lower shock bolt and nut
Rear lower shock bolt and nut
Rear upper shock bolt and nut
Turbo shield bolt
I have found MANY online resources for genuine GM parts and they have diagrams for major systems like:
https://gmpartsheadquarters.com/200...ont_suspension-suspension_components-GH99395/
https://gmpartsheadquarters.com/200...tic_4-engine-turbocharger_components-GH99275/
But they don't show or list the smaller parts (like shock bolts).
I know I can replace them with basic hardware if I knew the size, but was hoping there might be a site with better parts lookup for small items.
If anyone know of any or has the ability to look up part numbers it would be greatly appreciated.
Thank you.
1,600
I bounce back and forth between GMPartsGiant and wholesalegmpartsonline (Nalley GMC)
Rear bolt/nut (top and bottom)
resource
11611959, BOLT, HEXAGON W/CONICAL WASHER,M14X2X85,45 THREAD,28 OUTSIDE DIAMETER,10.9,GMW3359(REAR SHOCK ABSORBER)
resource
11516382
NUT, HEX FLANGED HEAD LOCK M14X2X15,28 OUTSIDE DIAMETER 10 7111M(REAR SHOCK ABSORBER)
Front bolt/nut
resource
11516871
BOLT, HEX FLANGED HEAD,M14X2X65,34 THREAD,30.5 OUTSIDE DIAMETER,10.9,7114M,MACHINE,HEADER POINT(FRONT SHOCK ABSORBER BRACKET)
resource
11516382
NUT, HEX FLANGED HEAD LOCK M14X2X15,28 OUTSIDE DIAMETER 10 7111M(FRONT SHOCK ABSORBER BRACKET)
Turbo Heat Shield
94011755 BOLT,EGR VLV CLR H/SHLD(03.405). Required: 02
For: CK2,3 6.6-2 DURAMAX(LLY),6 SPD A/TRANS(MW7),CALIF EMIS SYS(NC8),FEDERAL EMIS(NF4),TIER 2 PHASE-OUT FED EMIS(NT9)
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
899
29
Western MA
www.matpa.org
Thank you Tom!
I do get the following when trying to click your links or when googling the part numbers and try to click on GMPartGiant site:
This site can’t be reached www.gmpartsgiant.com’s server IP address could not be found.
Try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
dieselfan, thanks for the response. That is one of the sites I tried to use but unable to locate the items I was looking for. It could be a case of me looking in the incorrect spots of their site though (wouldn't be the first time I've made a mistake).
