I am changing antifreeze in my 2006 LBZ, but I can not get all 25 qts out. I only get about 1\2 out by pulling the lower rad hose and opening the air screw. I flushed 3 times so far, but still not draining clear.
My question is what better way to drain the fluid. And if all you can drain is half, should I refill will 100% dex-cool. 12 QTS remaining water and 12 QTS new antifreeze?
Tks all
Tks all
