I imagine you can shift it fast as you want. As long as the last clutch releases fast enough.
PureHybrid Isuzu Shakes IT Feb 15, 2012 3,931 830 113 Central OH Mar 31, 2015 #21 I imagine you can shift it fast as you want. As long as the last clutch releases fast enough.
Mike L. Got Sheep? Staff member Vendor/Sponsor Aug 12, 2006 15,681 236 63 Fullerton CA Mar 31, 2015 #22 mike diesel said: Someone also said the allison tuning does not go to neutral in between shifts..he says gm programmed allison to do it. He said you can shift an allison as fast as you want without tieing up gears. Is this true? I find it hard to believe. Click to expand... Who said that?
mike diesel I'm alright. Sep 6, 2012 4,005 0 36 SLC, Utah Mar 31, 2015 #23 This cat over on comp d. bwdt said: This a GM programming trait not Allison 1939 Programing. So no neutral between shifts. Click to expand...
