Then the wire colors will be just like I said and right at the steering column. Bcm is right in front there when you pull the under dash panel off. Two 7mm screws one on the right and one on the left. Take the fuse panel cover off then pull the panel on each side. There will be one clip on the left under the light switch (in that area) then one on the other side below the gear shift. Some times they are hard so just give it a yank. It may be easier if you pull off the the panel that goes around the gauges, radio, ect... first. Clips all around that panel. Just start in one area and work your way around. Put the shifter in 1st gear. Just watch the flasher button on the steering column when pulling it out.
Then once you have the under dash panel of there will be a metal bracket covering all the ignition wires. 4 10mm nuts holding that on. Once you remove the panels it will all be right there in your face.
