Air filters for High CFM air flow?
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
What filters sizes and media type is everyone running for componds or big singles? When i built my compond kit, I just ordered a normal style 5 inch AFE pro 5R, but it seems to be sucking it flat or atleast distorting the filter. I ordered a oval filter to try to get more surface and switched to a Pro Dry S media. From what a gathered from the AFE guy I talked to the oiled filters are designed for the media to tear when they get dirty to attempt to deliver max air flow. I think I would rather just blow out my filter every oil change than get a new one about every 10000 miles. Granted I think I need to set up to a 5.5 or 6 inch filter for the S488, but that big of 90 degree bends are hard to find especally with a tight radius.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
photos
gmduramax
Shits broke
Jun 12, 2008
4,190
329
Nor cal
You’re going to need a much bigger filter, or two. My plan is to run a tube down to the bottom of the grill with to filters and build a shroud so water doesn’t get to them.
rcr1978
793
Spring Creek, NV
The current one i'm using on my twin truck is a AFE (72-90041) with a pre filter (28-10143) . I also used 5" 90 with a 5.5" radius from summit p/n APH-10796
I tried the AFE Pro dry first p/n 21-90041 and it let fine dust through so I went back to a oiled filter the pro gard 7 above, no more dirt with the oiled filter. I'd rather clean a MAF every once in a while then dust my motor.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
I have thought about making an air box that panel style filter the sides and floor vs a single filter. I don't think that the 5 intake pipe is an issue, its more about how many CFM of air you can put threw a filter that is 6in diameter by 9in long.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
Were you running a prefilter with the Pro Dry as well?
The older filter was AFE Part Number: 24-91039 and the new one is AFE Part Number: 21-91044 if anyone wants to see sizes
8,247
realisitically, you wont get a filter large enough for the CFM flow and filter air as it needs to be. And 10k before cleaning the filter? damn! id go every 3-4k (an oil change for me) and clean it.
i ran the largest filter AFE made in the pro7 at the time and it was an oiled one. Dry filters just dont catch the fine fine particles unless its a stock paper style.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
Generally it would have been cleaned at every oil change, but of that 95% was highway driving.
rcr1978
793
Spring Creek, NV
Yeah I was but I also live in Northern Nevada to so quite a few dirt roads have the powdery bug dust. Maybe the prodry might be ok on street truck that never see's a dirt road but who knows.
I'd build a air box I've been wanting to do something for a while because my intake air temps have got up to 160+F (50-60 over ambient) in the summer towing. I been dinking with it trying to box the filter in and got it down to 20ish over ambient working the truck hard. Unloaded it's fine usually within 5-10 degrees, I think the only way to get it decent is build a box or somehow get some filters out of the engine bay.
slowlml
Undercover Epa agent
Feb 6, 2015
577
53
Strasburg Va/Wardensville Wv
S&b will custom make you filters. At least they use to cause i had it done on another truck of mine. I'm running a power driven diesel on my race truck and have been happy with it so far.
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
Look at the stuff PDD has. Filters are made by R2C
I did, but according to there website, they are out of stock.
I not on gravel or dirt very much, so hopefully it's not a problem, I did order a prefilter, hopefully it works. I think the air box filter will be the best for everything overall since the under hood temp can hurt overall performance.
3,796
423
I run the same AFE filter as you, and do the same thing to it with my S371. I've stoved in 2 of them so far. Bought the 7-layer version and that one is in one piece still, so maybe it works better?
I wish I could even get 5k miles on a filter. They're usually black as can be by 3k miles, and if I run them to 5k they stove in like that. I wish there was more room on the right side of the engine bay for a huge paper element like they run on the Ford 6-leaker or medium duty trucks.
08lmm72mm
544
169
Canada
I use Banks CAI on mine with a DP 72mm. I'm using banks dry version of the filter and can go 50,000 miles without a problem. Banks filter is large. I'll post a pic of what my filter looks like after 10,000
