Hello to all on this Forum. i have been following this forum and doing alot of reading and research. I am currently doing a complete overhaul on my frame and suspension on my 02 CCSB. I have the motor out due too blown head gaskets too,
I plan on running a S475 over stock IHI turbo with carrillo rods, keyed cam and crank, ARP main and head studs, 45% over injectors and LBZ pump and EFI Live to start. Then maybe add dual fueler later on to top out the S475 over IHI set up.. my goal is to get 700-725 HP. From what i read this could possibly be done with the dual fuler set up. SO, still in question is the stock balancer fine or is it worth the $420 ATI balancer? and will i be OK with the stock Cut LB7 Pistons? how about the Hamilton valve spring? are they worth getting for this combo? I know they make a big difference with the BIG turbos, just wondering on this set up
thanks
thanks
