500hp lb7 looking to get in 12s or faster..... should use nitrous or meth
jacobdewey
This won't last long...
Jan 14, 2011
972
I was running a 13.1 @103. I put my truck on a diet, and worked on my launches and then I ran a 12.6 @ 107
jacobdewey
Jan 14, 2011
972
Btw that was on a 510 hp tune. T bars all the way down.straight centerlink and PPE tie rod sleeves. I only cut a 1.7 60'
Dudgy
Runaway
Jun 1, 2010
416
Alberta
My truck weighing 5780 and 5980 with me in it went 12.05 and I dynoed 520. Weightloss helps big time. My 60's were around 1.60-1.65
Dirtymaxx03
3,110
31* degrees of timing sounds like a pretty big tune. Should be plenty of power to get your truck into the 12's
n20z28
Mar 17, 2013
yes I am only launching around 8 to 10 pounds I'm waiting on my braces I have sleeves on already hopefully I will try and leave harder and get the front and down a little more and I'm thinking about trying to use the leaf spring Clamps but first comes first I'm going to put on a diet and do some Logging... is everyone here mostly with the street trucks running on open front diff factory
n20z28
Mar 17, 2013
I notice between my 150Hp in 2 wheel drive my mile an hour was only 98 now I have a 200 and I'm only still at 98 in 4 wheel drive... so hey I figure my 4 wheel drive is rObbing some power somehow or b I am NOT making the power
05chevy
1,086
I believe everyone. Runs a open front diff. Or u wouldn't.keep it.on the track. Ever road in a fwd. Car. All over.the.place. my trick went 12.35 on stock turbo. 6200lb. Run 30 psi in front tires and 25psi in rears. Also leave on.about. 12-15 psi of.boost. that was a sweet spot for.my truck. I have left a 30psi and.broke stuff. Get your front end fixed.and. pull some weight out of the truck. Good.luck and have fun
Dirtymaxx03
3,110
Whats the general rule? For every 1/10th you knock off the 60' you drop your ET 2/10ths or something like that
Noreaster
2,910
42
Cape Cod,MA
8.63 1/8 @79.... 1.9x 60
You need to knock that 1/8th ET to around 8.2 to run a 12, the mph is a couple mph slow too
Obviously like everyone else said you need to work on that 60ft
air pressures, spring clamps on the front of the leafs & good shocks will help the 60ft
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
What track is it? Altitude has a HUGE factor... People have done 12's with a stock trans at sea level, where in high election tucks with built trans, turbo, and injectors barely make it in the 12's... Full weight that is.
n20z28
Mar 17, 2013
Tulsa Oklahoma... my truck is heavier than I thought... it weighs 7040 with me in and 1/4 tank
