3 bolt downpipe flance?
05Monsterdmax
May 31, 2011
119
Going to delete this piece of crap 2015. Tired of having multiple issues and only having 2500 miles on it. My issue is this truck isnt a vband connection at the downpipe exhaust connection like in prior years. Figured it swap downpipes but are they the same as previous years? I couldnt look and see with all the crap they have piled on these new motors, but did see it has some sensors on the upper curve of the downpipe. Does anyone have exhaust for a ccsb with a 3 bolt flange?
02greysixer
1,829
7
North Central FL
If it is like earlier lml's I believe you only have the 9th injector nozzle in the downpipe. There may be an egt probe too, I don't remember. Either way if you're deleting it you don't need to worry about them anyway. So any downpipe that fits the turbo will work.
rgullett83
1,607
Illinois
Or cut the factory and the new piece and make 2 into one
Dallas S
496
Alberta
Flowpros website says to use 11-14 exhaust kit with their 11-14 downpipe if you have a 3 bolt 15
I've never personally done the swap yet.
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
We've done several kinda like Riley does. We just cut the very end piece with the 3 bolt clamp off the stock exhaust & weld it to flo pro front pipe. No other way I know of.
05Monsterdmax
May 31, 2011
119
I looked at cutting it today. May go that route and just use a blocker plate on the egr, then reroute the pcv
plowboy_lbz
Farmer
Aug 6, 2013
431
Friend of mine deleted his 15 1/2. Had to buy mbrp DP to avoid the 3 bolt flange. He said it bungs in the DP for sensors and what not.
