2019 Turbo Actuator Going Rogue
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
Somewhere On The Ohio
www.marinemods.us
I've heard this is not uncommon, so what's the deal with the L5P turbo actuator waking up at odd hours for no reason, thus draining the batteries? A quick search, and think I see possible link to a corrosion in the NOX modules connectors. But not familiar with that actuator, guessing it's CANbus controlled, or is it hardwired to ECM?
A buddy called me to come check out his bone stock 2500 that had just rolled over 100k, because it set a MIL and was saying power reduction within XX miles. Quick scan, spotted these lost comms to NOX Modules and TCM.. Knowing GM's daisy chained structure, I instantly said likely has moisture in a plug somewhere. Cleared the codes, he drove it next day, and called to say the mileage countdown had stopped..
My question, will a flaky CANbus connection cause the turbo actuator to randomly wake up and check / adjust vane position? I monitored it's normal wake up movement when you open door and bus comes alive. Also then move to opposite range set when the head unit finally goes sleepy. Also checked operating range with EFIlive, seems fine. But what my friend reports, is when truck locked and keys in the house, he's hearing that actuator moving for no reason when everything else on the bus is obviously asleep. Just replaced the OEM batteries few months back, and says if leaves truck parked for two week, batteries are drained.
Curious becuse couple techs have said, ah that's just a normal L5P. To me, anyting CANbus waking up unattened, tells me it's always powered, and using some Wake On Data logic.. But he claims nothing else on the truck is responding, like dash or head unit.. Just some weird noise under the hood..
8,045
The actuator cycling randomly is not going to kill batteries over night. It would literally have to be stuck on.
Nox modules go bad all the time and kill the can circuit, not just corrosion.
I’d isolate whats killing the can line and address it. Its probably allowing crossfeed of power into areas it shouldnt making shit cycle that it shouldnt.
If you ohm the gm high speed can, does it come out to 60ohms? Iirc its 6 and 14 on the aldl
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
www.marinemods.us
I haven't checked resistance on the bus yet, just told him go put some miles on it and report back. But yes, I recently discovered the T87A's for example, won't TX a bit if no CANbus terminators present. 120 only, they will brick on a CANbus write. Certainly more picky than the nodes of older years.
I like your Nox module going bad, and shorting to CANbus. That would likely do it.. But this MIL level issue just showed up after he replaced both batteries. And said first time left it parked for few weeks, was dead when opened the door.
He felt this issue had killed the OEM, batteries. Then I did some quick math and said, "you actually got 5 years out of OEM battereis?"
I also checked those NOX sensors with the scanner. At Idle #1 looked nomral, but #2 was showing negative values. Another buddy said ya gotta drive it to check, so be next step. But past couple hundred miles, she's still happy.
kidturbo
Piston Tester
Jul 21, 2010
2,777
1,768
www.marinemods.us
Dead battery Issue returned with cold weather. Same issue with something waking the HS LAN, identified by the turbo actuator randomly going nuts again.
Based on the DTC list above, and the fact it had 20 plus codes related to Low Voltage when the batteries died, we inspected and applied dielectric grease to All the Ruductant and NOX senors on the the bus. Couple days later, I went back and checked the codes again. Caught a few new ones this time, and kinda looking like Fuel Pump Control module or BCM connection now.
I cleared the DTC set again, and the owner planned to keep the charger on it while parked. Heading to do another scan today, hopefully narrow it down to a CANbus only set. The one node on frame that I didn't disconnect and grease up last week, the Fuel Pump.. But according to docs, the BCM, and the Gateway Module both jumps that circuit to the chassis nodes.
Saw that TSB on the Fuel Pump Module, but that states 19-20. Truck is an 18, and runs fine, but that's where I'm headed next. The whole weather part of this issue makes it more interesting. Colder it is, faster it drains the batteries.. But some grease seems to have cleared the emissions hardware codes...
