2016 Won't start
Woody35
85
Sounds like something is obstructing flow through the pump. If you have fuel at the filter then it is inside the pump. Fass is a flow through design. I’ve had a fuse pop on me and I was still able to drive the truck without the lift pump running.
Or like mentioned before it could need to be primed. Make sure you have a gasket on the suction filter. Follow the instructions for priming. Take off the hose to see if you have any discharge at the pump
16T
Apr 2, 2026
13
3
Hockley, TX
Yeah, I'm putting the tank back up tomorrow. So once I have everything installed again, I'll walk through the typical priming sequence and see what happens.
