Hot COCOAL submitted a new Showcase Item:
Read more about this showcase item here...
Baaaaaaadddd assssssss LBZ, but 12 seconds is still slow
Needs more fuel, and a built engine!
Special thanks to Dave and Matt @ Ultimate Transmission
Mark Broviak and the crew @ Danville Performance
Parts from (and not limited to)
Exergy
Cognito
EATON
Yukon
Calvert industries
Air Dog
All Seasons
HSP
BT Dieselworks
Turbo performance
ATP
SoCal Diesel
DEI
SSBC
PPE
SDP
BD
Banks
Rare Parts
Hellwig Engineering
TOYO tires
MOTO Metal wheels
Went from this
To this
Added a smaller performance turbo, had a VGT72, now running a stg2 3794va
A custom fuel set up, here's the pressure gauge coming off 1/2" line from the AD2 165 and the return line distribution block
The final product
Finished it off with a MBRP 4" Turn Down
Still stock, and $broke$
DP stg2 3794va,Exergy 60's, built trans by Ultimate Transmission with triple disc stall and billet input/output, Sonnax pump rub kit, cognito NTB 4", 35's on 18x10's, 4.10's and Eaton TruTrac, overloads removed, Deaver 2" leafs, AirRite 5000 helpers, CalTrac's, PISK, SuperSteer idler pivot, Hellwig BigWig swaybars, EFI-Live on custom mounted keyloc DSP-5, BD intercooler, SDP 3" cold side and EGR delete, HSP 3" hot side, Banks Ram Air, ARP head studs, DHD Y-bridge, DHD HPPS lines, custom fuel supply and return lines, AD2 165, DRP fuel tank sump, DP pinned H2O pump, Mishimoto rad hoses & T-stats, SoCal billet flexplate, SoCal/ATI super damper, PPE gauges, PPE deep pans, BT lock up box, SeaTrab trans cooler, DRP 5/8" trans cooler lines, PPE manifold/up-pipes, DE 3" downpipe and MBRP 4" TD series exhaust, DEI heat wrap and some rattle can color scheme :thumb:...
