2006 lbz washed motor wont start
Clint330r
Clint K
Feb 25, 2015
17
Roosevelt Utah
I have a 2006 lbz i washed the motor yesterday in my driveway i sprayed some cleaner then rinsed it with water. I got in truck today to move it all the lights on the cluster was flashing on and off. Sometimes it will try to start when i turn key to acc. but it wont start. Also when when i disconnect the tcm all the light in dash and everything acts normal could the tcm be bad and can i just replace or do i need to program a new one thanks
Dozerboy
5,088
683
TX of course
Thats pretty odd I always wash my motors and never have an issue. What are the temp there? You may have got some water somewhere and it hasn't dried out yet. Got any way to heat and dry out the engine compartment faster?
Clint330r
Clint K
Feb 25, 2015
17
Roosevelt Utah
Temps around 60 today I parked it in the sun opened hood and disconnected most the plugs but only one that would make truck act normal is if I disconect Tcm
Dmax87
171
Might wanna check battery connections as well. Definitely something goofy goin on there, but weird things happen with weak batteries and bad grounds.
Clint330r
Clint K
Feb 25, 2015
17
Roosevelt Utah
Ok i grounded out Tcm truck tried to start with it in the acc position any idies could it also be the ecm like I say with the Tcm unplugged everything acts like it should but when plugged in it goes crazy
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Go buy a can of WD-40 and start disconnecting plugs one at a time and spraying them, especially the ECM (completely disconnect and spray) and the TCM, silicone spray works also..
WD-40 = water displacement formula number 40....
