I was shared this couple days back by someone who's been playing with 10L stuff and big power for a couple years. Answers one main question I had in first couple minutes. The 10L1000 is Allison in name only. These are basically a 10L 80/90 with scaled up internals. Which one would typically say great. But they share the same valve bodies with other 10L's. And from everyone swapping or turning I've spoken two about these 10L units, GM is chasing the problem much like they did the CP4's. New part # appearing every other week. However there is way more of these bodies to be replaced, and aftermarket does seem to be leading the charge on this.
Not endorsing anyone, but I am currently working with a one of these modified valve bodies in a Frankenstein Ford/GM 10L90 build. Big power Holley EFI controlling T87A in a stand alone mode. It recently ate a clutch set, due to what we think was a body leak. Upon inspection, it had also deposited clutch material in one of the solenoids, and thus wedged the slider. Some crazy flow routing, such as controling flow to and from the converter, and I beleive that was the valve it stuck. So they upgraded the body, and I'm back to leaning what normal shift times and slip are supose to look like..
As most of you know, tranmissions are about as far outside my wheelhouse as ya can get. So when I keep hearing similar reports from multiple tuners and racers about these things randomly freaking out and eathing themselves, it must be wide spread.. Since most of the case I've encountered are in swaps, everyone is questioning the torque data.. As they are heavly torque based and adjust shifts times on it. And unlike our old Allison 6 speeds, these new 10's don't seem to limp on slips. Ever.. You're probably gonna smell it before the TCM tells you there's a problem. I could be wrong on 1000's if the OS is way different, but I am betting not. What's worse, Ford's don't seem to suffer from this problem, and the only big difference is TCM and valve body...
Source: https://youtu.be/m2GwZ0JPAMM?si=Fy9Q-B4K9chv2T34
