Are there any mechanical differences in the 08 LMM Allisons compared to older ones?
Are all actuators the same on my 05 Ally (except for 6th speed obviously)?
yep no input speed sensor...will ONLY work on an LMM. I suppose you could change the bellhousing tho.
The 6 speed changed the front rotating drum to a better design and more holding power. Valve body changed slightly also.
