06 CV-Axle problems
06LBZCrew4x4
Aug 12, 2017
11
Florida
Hello,
I have a 2006 Duramax 4x4, cc, sb, and I need to replace a CV-Axle, Wheel is off metal dust cap is off, I can not move that nut, Air Impact, Bracker bar, etc. It shouldn't be that hard to remove that nut I wouldn't think? I hit it with some P.B. Blaster let it sit, hit it again, 15 minutes later tried it and nothing. Is there a trick to this or something?
Thanks in advanced, if this is in the wrong section I am sorry please move. Still new to forum and trying to learn stuff. Thanks again
BOBBYDIESEL 14
Dec 2, 2016
15
I would try some heat with a torch then followed by some p.b blaster should do the trick.
Sent from my Z956 using Tapatalk
Robby Avery
GM TECH @ FENDER GMC
Jul 31, 2008
820
Norman Park, Georgia
Have you tried tighten then loosening it if you bump the air impact 2-3 the try loosen it something about the high frequency vibration that jars it free hope that helps
Awenta
4,090
You're changing it anyway. Bigger cheater bar or bigger impact gun. It's a self locking nut so they can be tough sometimes.
