LLY: 05 duramax wont accel over 2000 rpm?
burgess.jase7291
Apr 26, 2016
21
My duramax recently started an issue where it won't get over 65mph or 2000rpm and it looses all power until I let of pedal...as long as u baby it or keep it under 2000 rpm it seems fine . Anybody else ever had this issue...Changed all my filters today and exact same thg
Sent from my SCH-I545 using Tapatalk
minerigger
2,660
Casper, WY
Mine did it when I changed turbos. MAF sensor had to get seriously rescaled. If it's tuned via efilive I'd log it and send it to your tuner
burgess.jase7291
Apr 26, 2016
21
P1098...fuel rail pressure low while power enrich...doesn't have a tuner on it yet...just bought it...I'm gonna check frp today and run injector balance test but this is my first duramax. Hoping I don't regret it
onebaddmaxxx
1,212
Cecil County Md
Frp low during power enrichment should be a p0093 code. P1098 is for o2 sensors on gas trucks.
I would pull the small rubber loop on the back off the driver rail and see if fuel comes out in a test drive. If so your relief valve is bad.
burgess.jase7291
Apr 26, 2016
21
Small rubber loop?
carl.swoyer
Jan 31, 2016
90
Got that when the #2&#7 injectors shorted. It was a recall on the 05 lly
Carl & Christine, 2012 Landmark Rushmore, 2005 Silverado crew cab lt 8 foot bed 6.6 lly /Allison -custom dual exhaust-198000 miles !
carl.swoyer
Jan 31, 2016
90
Also had a bad fuel rail pressure solenoid.
burgess.jase7291
Apr 26, 2016
21
Look at the back of the driver rail you will see a rubber horse shoe hose. Pull it off and see if any fuel is in there
Ok I found it...if I bottle test it and there is a large amount or any fuel in the bottle what would be the culprit or is there many things to cause this
burgess.jase7291
Apr 26, 2016
21
Yes it will work. They will all work 01-10, only diff is some minor inner parts and the fpr on the 06 up, but they all inter change
Thx for the info...do they have a gasket or o ring of any sort I need to pick up before R & R
