05 cab & chasis-likes to hop
Brassfield
Jan 14, 2014
185
West Plains, MO
Got an 05 2.5 truck, cab and chassis. I have all the normal stuff done, hitch hooking point moved up, t bars lowered, rear suspension stops, center link brace. For some reason though I keep lifting the left front and start hoping. We did notice the that only the left front tire is spinning so we are going to linclon lock the front diff, but I really don't think an open front end will cause the hop. Any thoughts??
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Driver error possibly? Need to work on your clutch skills?? ;)
He didn't mention but it if a zf-6 truck.
Brassfield
Jan 14, 2014
185
West Plains, MO
Yes traction bars. 285s on duals on the rear-50psi. had 305/55 20 on front, tried 50psi then tried 20 psi-same results. Going to put some 285s on 16s up front for this weekend
ecc_33
Junior Member
Aug 10, 2006
1,925
40
Amanda, Ohio
Best thing to do is get a very good video of it making a hook and post it. Usually the crowd here is very very good at getting stuff figured out with a pulling truck.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
I have a vid, if someone with an phone would like me to send it to em let me know. I don't know how to upload to you tube
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
A lot of "traction bars" are under built. Duals tend to bring out the weakness in these bars.
Figured that out on the first set of bars for this truck. This set should not have any problems
try running a little more gap between the stops. if I don't hang weight, I cant run solid rear, or else my front end hops
So do you have 2 sets of stops or just pull em out if you don't hang weight?
X2. Try one inch. And make sure u measure exact
Will measure and trim to exact 1"
His last pull truck was a crew cab long bed dually. I believe the stops were like 1/4" from touching with nothing in the bed. B/c if there was anything in the bed you had to jack the hitch up a little to get the stops in.
