01 Lb7 Swapped to LLY
Mar 8, 2012
108
Ohio
Yes another lb7 to lly swap on here lol
My 01 blew up last year I have a 04.5 now. Anyways i got another 04.5 lly for a really good price. already got my money back selling the body.
I really want to do the BT Diesel works wire harness so I can keep the LLY electronics and turbo.
Having some trouble getting ahold of him emailed twice and called twice at shop left one voicemail.
Hoping there was another way to get ahold of someone there.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Ben is busy with other projects.
Call or pm Russ at rpm motor sports and he can point you in the direction
Mar 8, 2012
108
Ohio
I finally got to this. Had 2 questions on the harness. I assume the plug on the side of the fuse box isnt used now cause there isnt one? Pic one
Pic 2 is an pig tail that was added on. What kind of sensor is it for? I cant find nothing that doesnt already have somethibg pluged into it.
rfletes79
656
196
Galt, Ca 95632
The fuse box plug doesn’t get used. The other single wire plug is for your lb7 eop sensor, you need to move the sensor and standpipe from your lb7 over to your lly in the same location it was on your lb7. Your lly will end up with 2 eop sensors. One feeding the dash, the single wire pigtail in your pic above, and the factory lly 3 wire plug that is attached to the lly engine harness feeding the ecm oil pressure info.
Mar 8, 2012
108
Ohio
Finally got down time to get this thing goin. The tcase had to get rebuilt. Some of the fuel lines got crusty from sitting around. 2 injector pig tails replaced. It fired right up. But weird thing it only turns over by bypassing the relay. Even swapped out the relay and checked all fuses. Wont turn over with an key.
Put all new trans line in. Even used the lb7 pcv lines for the reroute. Looks factory.
