Yes has a race cover. Bullseye billet S480 with a 1.32ARLooks like you have just about everything to swap it on. But you'll need to tap a drain line on the oil pan. I had my upper oil pan removed and welded an -12 o-ring boss at the front beneath the damper as I felt that was the best place to put it to accept a -12 jic fitting as I would have more options to make any changes using an o ring boss fitting. As for the air filter, I use AFE filter with a dust cover. Is it a race cover?
Yes I'm gonna have to drill and trap a hole in the upper pan for the drain. I've seen a picture of it done toward the back on the right hand side of the pan. Is there anything that dictates where I drill and tap other than what's convenient for the routing of the hose?
